Timothyah2
Dec 30, 2022Guide
Network switch not working with Modem/Router
Hello,    I recently attempted to install a network switch on my Netgear modem/router. My house is pre-wired so it was an easy plug and play. I had to dismount an TV to connect to ethernet and initial...
- Dec 30, 2022
1. AX6000 is a speed, not a model. Do you have the CAX80?
2. did you try other ports on the router?
3. some devices are more picking with sketchy cables. If you move the switch to right next to the router and connect it with a good quality cable, does it work?
Timothyah2
Dec 30, 2022Guide
I forgot to add I have a AX6000 modem router combo and a tp link simple 5 port switch.
- plemansDec 30, 2022Guru - Experienced User
- Timothyah2Dec 31, 2022GuideHey sorry for the confusion. Yes I have the CAX80. I did What you recommended and moved the switch next to the router and it worked so I’m assuming the cable may be bad. Thanks for your help!
- plemansJan 02, 2023Guru - Experienced User
It might not be the cable itself but just the ends. I've had to redo ends before for sketchy connections.
