dknaggert
Mar 14, 2017Aspirant
Network switched
I've set-up my own home hetwork for both 2.4 and 5.0 GHZ. Sometimes they will fail and there is no way for me to access the router wireless. So, I reset the router and/or power it down and it will wo...
DarrenM
Mar 17, 2017Sr. NETGEAR Moderator
Hello Dknaggert
Sounds like the unit keeps factory resetting I would check the power strip its plugged into make sure its getting a good power source if it keeps doing it you may want to contact Netgear support if its under warranty.
DarrenM
