Nov 10, 2023Guru - Experienced User
New - CAX30 Firmware Version 2.2.1.12 Released
New Features and Enhancements: 11/09/2023
- Re-introduce the Traffic Meter feature.
Bug Fixes:
- Improve WiFi stability.
- Enhance system reliability.
- Fix security vulnerability issues.
- Various bug fixes.
For more information about security vulnerabilities, visit >https://www.netgear.com/about/security
Download Link : https://www.netgear.com/support/product/cax30.aspx#download
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page.
NOTE: This upgrade is for the ROUTER portion of the CAX only. Modem portion Firmware upgrades are pushed down by your ISP. For more information, please see our https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-mod...
To Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW.
If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This article applies to:
Let us know how it works for you...
- Racerboy80Aspirant
Why do you recommend setting the DHCP range between 100 and 200?
