inteller
Sep 11, 2014Apprentice
New C3700 cannot make address reservations
Title says it all. I cannot make dhcp reservations for my lan devices. Get this stupid message that the table is full even though it is empty.
jcmegabyte
Nov 20, 2015Aspirant
Yes - this solution DID work for me. Once there is an entry in the table it seems to be fine... Thanks! =)
egruff
Dec 13, 2015Aspirant
There's a problem with this approach (besides faulty firmware that should be updated). I got this to work, and have recently gone back to add another static IP, but because some of the previously-assigned static IPs are "above" 192.168.0.20, I can't reassign the range of addresses without deleting all the existing ones and then adding them all back. Why can't Netgear just fix this issue and put out a firmware update instead of users having to kludge around a problem?
