inteller
Sep 11, 2014Apprentice
New C3700 cannot make address reservations
Title says it all. I cannot make dhcp reservations for my lan devices. Get this stupid message that the table is full even though it is empty.
srandlet
Oct 19, 2014Initiate
I've got the C3000 Firmware V1.01.05. I was having the same issue with it.
I was able to get it to take reservations by doing the following steps.
1) In the Advanced/Setup/LAN Setup screen, set the Starting IP Address to .10 (default) and Ending IP Address to .20
2) Apply Config
3) Click to add reservation. It will then pop up IP addresses that have been assigned. Go back and change the Ending IP Address to .254 (or whatever you want to use as your end IP address).
4) Apply Config
It will then allow you to add. Note that reservations IP addresses must be part of the pool. So if you want to reserve x.y.z.200 then the IP pool range must include .200. Typically when you setup DHCP reserved addresses they are not part of the pool but this device works differently.
Hope this works for you,
Steve
2) Apply Config
4) Apply Config
Steve
- teeben70Nov 09, 2015Aspirant
Thank you for your tip, srandlet!
It worked for my C3700-100NAS.
Cheers!
-teeben70
- jcmegabyteNov 20, 2015Aspirant
Yes - this solution DID work for me. Once there is an entry in the table it seems to be fine... Thanks! =)
- egruffDec 13, 2015Aspirant
There's a problem with this approach (besides faulty firmware that should be updated). I got this to work, and have recently gone back to add another static IP, but because some of the previously-assigned static IPs are "above" 192.168.0.20, I can't reassign the range of addresses without deleting all the existing ones and then adding them all back. Why can't Netgear just fix this issue and put out a firmware update instead of users having to kludge around a problem?
