inteller
Sep 11, 2014Apprentice
New C3700 cannot make address reservations
Title says it all. I cannot make dhcp reservations for my lan devices. Get this stupid message that the table is full even though it is empty.
rberthelette
Mar 02, 2015Aspirant
Thanks SRANDLET! I was able to see the reservations by following your steps:
1) In the Advanced/Setup/LAN Setup screen, set the Starting IP Address to .10 (default) and Ending IP Address to .20
2) Apply Config
3) Click to add reservation. It will then pop up IP addresses that have been assigned. Go back and change the Ending IP Address to .254 (or whatever you want to use as your end IP address).
4) Apply Config
The problem seems to be when a reserved device has no Device Name. After following the above steps, simply give each device a name.
Once this is done, then the starting and ending IP reservation addresses can be put back to what they were and you should now see your reservations listed.
2) Apply Config
4) Apply Config
