gkski
May 15, 2025Aspirant
New CAX30, Xfinity Issues
I was using an older Netgear Modem and Netgear Router and Comcast told me it was no longer in their recommendations. For a couple of years they told me I was at the 800Mbps service tier (started off...
May 15, 2025Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
gkski
May 16, 2025Aspirant
Hardware Version
V1.01
Firmware Version
V2.2.4.2
Cable Firmware Version
V1.04.10
Connection Status
IP Address | xx.xx.xx.xx 2001:558:6017:43:d5fe:6c61:5418:349c |
Subnet Mask | xx.xx.xx.xx 128 |
Default Gateway | xx.xx.xx.xx fe80::21c:73ff:fe00:99 |
DHCP Server | 0.0.0.0 |
DNS Server | 75.75.75.75, 75.75.76.76 2001:558:feed::1 2001:558:feed::2 |
Lease Obtained | 0 days, 2 hours, 0 minutes, 0 seconds |
Lease Expires | 0 days, 1 hours, 42 minutes, 19 seconds |
Event Log
Time | Priority | Description |
2025-05-16 08:14:01 | Notice (6) | CM-STATUS message sent. Event Type Code: 24; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=2xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
2025-05-16 08:12:25 | Notice (6) | CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
2025-05-15 14:51:28 | Critical (3) | UCD invalid or channel unusable;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
2025-05-15 14:51:28 | Notice (6) | DS profile assignment change. DS Chan ID: 33; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
2025-05-15 14:51:27 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
1970-01-01 00:00:31 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
1970-01-01 00:00:25 | Critical (3) | UCD invalid or channel unusable;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
1970-01-01 00:00:24 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
2025-05-14 12:57:11 | Critical (3) | UCD invalid or channel unusable;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
1970-01-01 00:00:26 | Critical (3) | UCD invalid or channel unusable;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
2025-05-14 10:19:21 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
- FURRYe38May 19, 2025Guru - Experienced User
There is more down the page for the connection status if you can post that as well.
For the event log, Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
- gkskiMay 20, 2025Aspirant
No. That was the complete Connection Status from the advanced page. I will have to get Comcast involved but not hopeful.
- FURRYe38May 20, 2025Guru - Experienced User
There will be more to that page, be sure you SCROLL Down the page. It will look similar to that is posted here in this thread: https://community.netgear.com/discussions/home-cable-modems-routers/re-switched-from-cm3000-to-cax80-and-it-destroyed-uploaddownload-speeds/2455450
