EverymanToo
May 28, 2025Tutor
New CM205V Interferes with TV Signal
When a CM2050V is connected to a three-way coax splitter (the modem, and two TVs to Xfinity Voice/Data/Cable television service, it disrupts the signal to the two tvs. Disconnect it, and the TVs are...
- Jun 05, 2025
Way too many correctable/uncorrectable errors for a 24 hour period of time.
DOCSIS 3.1 is backward compatible with DOCSIS 3.0. I do not think DOCSIS 3.1 is backward compatible with DOCSIS 2.0. If you are looking at DOCSIS 2.0 hardware, you want to check the coax type to ensure it is correct for the current DOCSIS 3.1 connections (RG6).
What were the upload/download throughputs with your new splitters in place?
You might find some ideas in chapter 3 of this reference: https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
EverymanToo
May 28, 2025Tutor
How 'bout this one? (on amazon)
GE Digital 2-Way Coaxial Cable Splitter, 2.5 GHz 5-2500 MHz, RG6 Compatible, Works with HD TV, Satellite, High Speed Internet, Amplifier, Antenna, Gold Plated Connectors, Corrosion Resistant, 33526
May 28, 2025Guru - Experienced User
Please post a copy and paste of the modems connection status log page.
Which ISP are you connected with?
