judyw988's avatar
judyw988
New Modem
Comcast modem when out, got new one, now unable to contect to router.  I feel like I have followed the suggestions noted here but to no avail.  I am sure it's simple.  Thanks....
Windows computer
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    make sure you are holding the reset button for 10+ seconds to factory reset the unit then try to connect it again.
    DarrenM
    • judyw988's avatar
      judyw988
      Thanks DarrenM......   appreciate you confirming that is indeed what I need to do....
