JeremyLothar
Dec 19, 2018Follower
New Netgear Modem installed and Now Can't Login to Router when Modem cable is connected HELP
I have had a r6300 for a few years with no real issues. I upgraded my motorola modem to a new netgear modem cm500 today. Internet works fine directly and when connected to the router, but now I can not log in to the router (192.168.1.1) with the new modem line connected. I can only connect when I unplug it and power cycle the router. I have tried from multiple devices/ browsers. I can ping the router and the genie app can see the attached devices. There has to be a weird setting inside the router that is conflicting with the new Netgear Modem.. The modem has an IP address of 192.168.100.1 but is just a modem and doesn't handle any DHCP Routing or anything so don't know why that would screw anything up. I can log into the modem when connected to the router but not the router itself. HELP!
Chrome
This site can’t be reached
192.168.1.1 refused to connect.
Try:
- Checking the connection
- Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
IE
Can’t reach this page
- Make sure the web address http://192.168.1.1 is correct
- Search for this site on Bing
- Refresh the page
- Check that all network cables are plugged in.
- Verify that airplane mode is turned off.
- Make sure your wireless switch is turned on.
- See if you can connect to mobile broadband.
- Restart your router.
More information<noscript><id id="moreInformation">More information</id> |
This website could not be found.
Error Code: INET_E_RESOURCE_NOT_FOUND
1 Reply
- DarrenMSr. NETGEAR Moderator
Does the default gateway address change on the router when connected to the modem?
https://wiki.amahi.org/index.php/Find_Your_Gateway_IP
DarrenM
