bsputnam25's avatar
bsputnam25
New nighthawk 1750 with existing C3700 cable modem/router
Looking for the least painful way to make a new R6700v2 nighthawk my new wireless router and DHCP server with an existing C3700 cable modem/wireless combo. My existing DHCP config uses class A numbering (10.x.x.x) and every attemp to manually config to class A network on the nighthawk leads to DHCP being configured to class C (192.x.x.x). It's been awile since I've configured these things and this home networking gear has advanced leaps and bounds. I know it is probably something simple that I'm missing but there is a work from home situation that I can't afford to be down for a day. Any advice would be apreciated!
  • > [...] make a new R6700v2 nighthawk my new wireless router and DHCP
    > server with an existing C3700 cable modem/wireless combo. [...]
       What is thae actual problem which you are trying to solve?  Are you
    interested in preserving the wireless router functions of the C3700, or
    are you trying to replace the router section of the C3700 with the
    R6700v2, or what?  Why add the R6700v2?  Extended wireless-network
    coverage, or what?
    > [...] My existing DHCP config uses class A numbering (10.x.x.x) [...]
       Forget "class A/B/C"; it's a long-obsolete concept.  Why do you care
    about the LAN subnet?
    • bsputnam25's avatar
      bsputnam25
      Trying to replace the wireless functions of the C3700, have had performance issues and several people have suggested the AC1750 for better prformance, as for the LAN subnet I would like to keep it the same as I have existing.
      • antinode's avatar
        antinode
        Guru
        > [...] as for the LAN subnet I would like to keep it the same as I have
        > existing.
           So long as your new configuration includes only one router, you
        should be able to choose whichever LAN subnet you want.  But, no matter
        to which "class" you think it belongs, if you try to use a subnet mask
        other than "255.255.255.0" (old "class C"), then I'd expect problems.
        > Trying to replace the wireless functions of the C3700, [...]
           C3700 or C3700v2?  Look at the product label.
           Visit http://netgear.com/support , put in your (actual) model number,
        and look for Documentation.  Get the User Manual.  Read.  Look for a
        topic like "Change the Router Mode".  With "Router Mode: No", the
        C3700[vX] should act like a modem-only, leaving the R6700v2 as your only
        router.
           The alternative would be to leave the C3700 router section active,
        and configure the R6700v2 as a wireless access point.  Get the R6700v2
        User Manual.  Read.  Look for "Use the Router as a WiFi Access Point
        Only".  That would/could leave the wireless stuff active on both
        devices.
           Either way, you should be left with one LAN subnet, which should be
        configurable on the active router.
