Toby2006's avatar
Dec 24, 2021
Nighhawk CAX80 Mystery Wireless IP Address
Posted this in the Nighhawk Wifi 6 forum.  Recommeded I try here.
Under Attached Devices I show a device using IP address 192.168.1.235.  It's identified as a phone and connection type is 2.4G Wireless.
 If 2.4g disabled device goes away.  2.4g back on it reappears.  Power level does not appear to affect it.
I have physically identified all wired and wireless devices but can't determine what this device is.
In the Admin Logs, it logs an event every ten minutes or so.  The count has been a high as 74 in one event.  Any idea what this could be or how to locate it?  Thanks.
  • FURRYe38's avatar
    Change the PW on the 2.4Ghz radio and see if that device connects or not or someone complains. You'll need to update wifi devices for this radio with new PW.
    • Toby2006's avatar
      Toby2006
      Guide
      "Change the PW on the 2.4Ghz radio and see if that device connects or not or someone complains. You'll need to update wifi devices for this radio with new PW."
      Can you explain what you mean by PW?  Password?
      The thought is to cahnge the WiFi password and see if it still connects?  If not I would need to update the password for all the connected devices to the new router password, correct?
      • Toby2006's avatar
        Toby2006
        Guide
        Under Advanced/Admin Attached Devices I selected "Block" on that device.  It still shows activity.  Is changing the password the only way to completely remove the device from accessing the router?
