doogiejb14's avatar
doogiejb14
Follower
Dec 11, 2023
NighHawk Voice Cable Modem CM2050V red light flashing on the Multi light
NighHawk Voice Cable Modem CM2050V red light flashing on the Multi light, there is no WIFI
  • FURRYe38's avatar
    What do you have connected to the WAN port on the CM modem?
    What CAT# LAN cable are you using? CAT6A is recommended.
    What does the user manual say for the MG LED on the modem.
    FYI, CM series modems do not have any built in router or wifi support. There only modems. You'll need a external wifi router system to connect to the modem for wider use with wireless and wired devices.
