Peter_Fiddes's avatar
Peter_Fiddes
Nightawk X4S D7800 Performance Issues
Has anyone else used a nighthawk X4S D7800 (one with modem) and had performance issues? I bought to replace a Home Hub 4 - put it in the same place, phone cable to the VDSL connection on the router ...
  • netwrks's avatar
    Jan 01, 2017
    Did you upgrade the firmware on the router? If you haven't upgrade the firmware. When completed reset to factory default and re-configure. In general, router modem combo's kind of suck, as you are dealing with two different piece's of firmware. One can affect the other, which makes it difficult to troubleshoot.
    • Best rate was 20Mbps on 5GHz (not the 1733 Mbps advertised) - pick a higher channel (don't leave at auto) - unless you have a .AC wireless client, you won't get close to the 1733Mbps. (typically total .AC connected devices throughput) Maybe 400Mbps throughput, unless you own a Mac Air. .N client throughput around 150Mbps.
    • 2.4GHz signal was ok, but no where near as good as HH4. - pick a channel (1,6,or 11). Don't leave at auto . Ensure WMM is enabled.
