JoeCAl
Mar 12, 2020Aspirant
Nighthawk 1150v not compatible with Comcast cable TV
Advised by comcast that 1150v is not combatible with cable tv only voice and internet. I think this should be clearly indicated on all information about modem. The current information indicates for Xfinity voice, the implication is that it would also be for cable. Is there a fix or update that would fix this broblem?
What features are available with the C7100V cable modem voice router and Comcast XFINITY?
Taking this - are there any plans to make it compatible with the IPTV "Stream" (wild guess from the other side of mother earth) feature vkdelta ? - FURRYe38Guru - Experienced User
Cable TV services required a separate Cable TV box connected to the ISP service. the CM1150v is a internet modem with phone support only. CM modems do not support any kind of Cable TV services. You have to get the cable TV service and hardware from your ISP whom supplys all that.
JoeCAl wrote:Advised by comcast that 1150v is not combatible with cable tv only voice and internet. I think this should be clearly indicated on all information about modem. The current information indicates for Xfinity voice, the implication is that it would also be for cable. Is there a fix or update that would fix this broblem?
- JoeCAlAspirantIt works on Comcast cable box but not on Comcast wireless box.
Thats because the CM modem doesn't have a router or any wireless built in. Again, CM modems are only modems. If you need wifi ability, you need a separate wifi router to connect to the CM modem.
