notadingus
Apr 02, 2020Aspirant
Nighthawk ac1900 c7000v2 has significant packet loss and high ping in gaming and video calls
I am completely baffled by my internet problems right now. I used to have a different router modem combo from netgear that worked pretty well for me, but after 3 years I started noticing problems (I started noticing it about a month and a half ago). In all the games that I played, I noticed some pretty severe latency problems and packet loss. This is across PC and PS4, wired and wireless connections. I checked with my ISP and they said things looked fine from their end. So I in turn bought a new router modem combo (Nighthawk AC1900 C7000v2) thinking that the hardware of the previous model was broken, but I continued having similar problems. I am pretty certain the hardware of this new model is fine, so I called some friends that live by me with the same ISP that play the same games that I do and they said they were having no issues. After this information, I called my ISP again and they sent a tech out to me and he fixed a couple of faulty connections. It still didn't help. They sent another tech out again and fixed a couple other things that already looked ok but were not quite "new" and it still didn't help. They think the cable connected to the modem is functional and good. This leads me to think that something is wrong with my router/modem. Therefore, I tried port forwarding and disabling and enabling different things from suggestions I found on the internet and it made no difference. It might be a firmware problem, but I don't know what to do next. I also live in an apartment complex, so that may factor some into this, but I am massively confused.
Be sure your wired when gaming. It's perferred.
Any other wifi nieghbors near by? If so, how many? If you live in a apartment complex, you may have some wifi congestion.
Might turn down the power on the wifi radios from 100% to 50% and see. Under Advanced Tab/Advanced Settings/Wireless Settings
You might contact NG support about an RMA. If the ISP connected a different modem and that worked and the NG doesn't, I would get another C series modem.
- notadingusAspirant
I am wired when I am gaming. There are several wifi neighbors nearby. At least 8 or so will pop up on my phone whenever I check. I will test the wifi radio power and see if that helps. But if I am plugged directly into it, would that change anything?
I have never used my ISP's modems because I didn't want to pay a monthly charge for it.
One way to find out is to turn OFF the wifi radios on the modem. Game over wired connection and see if you still see high ping. Turn off ALL other wifi devices in the home as well while gaming. Test and let us know.
- Anonymous
With C7000v2 I see ping time to local gateway (192.168.0.1) is intermittently happens to be around 40-50 seconds, over ethernet.
Was there any solution for this issue?
