Beetr00t's avatar
Feb 20, 2018
Nighthawk AC1900 dropping 5ghz broadcast
My Nighthawk AC1900 recently stopped broadcasting the 5ghz channel. 5ghz is still enabled in settings. If I reset the router the 5ghz channel will reappear for a bit, but none of my devices can connect to it. After a few minutes the 5ghz network disappears. I tried creating a guest 5ghz channel and it does not work either. Anyone have any ideas?
  • > My Nighthawk AC1900 [...]
       "AC1900" is a speed, not a model number.  Ever helpful, Netgear
    product packaging emphasizes speeds like "ACxxxx", but that's not the
    model identifier.  Look at the product label.
       Firmware version?
       Assuming that it's not a hardware problem, the usual first step would
    be to bring the firmware up to date (or load some old, working version).
    Then reset the router to its factory default settings, and reconfigure
    it.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Look for "Factory Settings".
    While you're in the neighborhood, firmware kits should be available
    under Downloads.
    • Beetr00t's avatar
      Beetr00t
      Tutor
      Thank you antinode. Sorry for the mididentification of model number, I grabbed that from the Amazon product page.
      Model C7000
      Firmware v1.01.28
      I did a full factory reset of settings and the problem persists. I called Netgear customer support and they told me it was a software issue that they "could easily fix in less than 15 minutes remotely" but that since the product is out of their 3 month warranty, it would be $149.99 for them to fix it. Pretty disgusted with Netgear at the moment.
      • antinode's avatar
        antinode
        Guru
        > Model C7000
           Ok.  Forget about updating your firmware (yourself).  For cable-TV
        modem(+router)s, the ISP has exclusive control over that.
           There have been multiple reports of wireless problems, on multiple
        devices, caused by lame firmware, so there is still a chance that fresh
        firmware will help.
