dewser
Feb 26, 2018Aspirant
nighthawk ac1900 R7000
I have an arris surfboard 6480 and I want to get the nighthawk ac1900 R7000.Does the nighthawk connect to my existing modem-router or is it seperate
dewser
it is the C7000 not the R7000 my mistake
Feb 26, 2018Guru - Experienced User
The C7000 is a cable/modem/router. This would be a replacement for the SB6480.
You might want to post here for the C7000:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
