Figguh
Sep 05, 2019Aspirant
Nighthawk ac1900 wifi cable and modem lag issue while gaming
I bought my Nighthawk AC1900 modem/router yesterday and managed to set it up using WoW internet easily to avoid using their modem that had seemed to break on me but now when I am gaming on Final Fanta...
Sep 06, 2019Guru - Experienced User
Are you gaming while wired or wireless connected? Wired is preferred.
What ISP speeds UP and DOWN do you pay for?
Any other bandwidth in use while gaming?
Figguh
Sep 06, 2019Aspirant
I am wired while gaming. Best way to do it after all.
My plan is 500 mbps for download and 50 mbps for upload.
There are a around 4-5 other devices connected and in use while I am gaming
- FURRYe38Sep 06, 2019Guru - Experienced User
Sounds like QoS isn't handling what going on well.
- FigguhSep 06, 2019AspirantQoS? And I'm going to get a modem and go back to using my Nighthawk X4S with it to hopefully fix the issue seeing as I had no issue with it and it was the old modem that WoW gave me that was the issue from what we figured
As a test what happens i you bridge the C7000 and connect your R7800 router to it?
