Figguh
Sep 05, 2019Aspirant
Nighthawk ac1900 wifi cable and modem lag issue while gaming
I bought my Nighthawk AC1900 modem/router yesterday and managed to set it up using WoW internet easily to avoid using their modem that had seemed to break on me but now when I am gaming on Final Fanta...
Figguh
Sep 06, 2019Aspirant
I am wired while gaming. Best way to do it after all.
My plan is 500 mbps for download and 50 mbps for upload.
There are a around 4-5 other devices connected and in use while I am gaming
Sep 06, 2019Guru - Experienced User
Sounds like QoS isn't handling what going on well.
- FigguhSep 06, 2019AspirantQoS? And I'm going to get a modem and go back to using my Nighthawk X4S with it to hopefully fix the issue seeing as I had no issue with it and it was the old modem that WoW gave me that was the issue from what we figured
- FURRYe38Sep 06, 2019Guru - Experienced User
As a test what happens i you bridge the C7000 and connect your R7800 router to it?
