poormr's avatar
poormr
Tutor
Jan 24, 2022
Nighthawk AX6000 (CAX80) add Mesh System
I have a Nighthawk AX6000 (CAX80) wifi cable modem router and I want to add a tri-band mesh system to my home.   I have about 4,000 square feet.   I am confused, should I install a Orbi mesh system or a Nighthawk mesh system? Or does it really matter which I choose?
  • plemans's avatar
    I would focus more on if you're wanting a dual band or a triband system.
    The MK and the orbi perform similar when they have similar specs so its more about what performance system you're adding.
    • poormr's avatar
      poormr
      Tutor
      I want to add a tri-band system but I didn't know what the difference was or the best between between the Orbi mesh systems or the Nighthawk mesh systems.  Maybe I am just splitting hairs.
      • plemans's avatar
        a lot depends on the performance/budget you want.
        In terms of performance/capabilities it'd go base system for triband: MK80 series, then obri 7 series, then 8, then 9 series.
        But they go up in price each step.
  • FURRYe38's avatar
    You might give the EAX80 a try with the CAX80.
