Wildguns84
Oct 27, 2017Tutor
Nighthawk C7000 AC1900 DoS attack with speed slowdowns
Hello everyone! I have tried going through my ISP but they see nothing wrong with modem health or my connection on their end. I have a Nighthawk C7000 AC1900 firmware version v1.01.23, with Windows ...
DarrenM
Oct 31, 2017Sr. NETGEAR Moderator
It seems to be coming from the same IP tried to remove your phone or tablet from the network one by one it could be some app causing the issues it will help you find if its coming from one of your own devices.
DarrenM
Wildguns84
Nov 01, 2017Tutor
Thank you for the reply!
So none of my devices are connected to my network. I switched to an ISP provided modem and the issues continue. Here is the event log and my signal levels from that modem.
| DCID | Freq | Power | SNR | Modulation | Octets | Correcteds | Uncorrectables | |
| Downstream 1 | 31 | 759.00 MHz | -8.30 dBmV | 37.64 dB | 256QAM | 10174456403 | 773 | 531 |
| Downstream 2 | 11 | 639.00 MHz | -3.80 dBmV | 35.78 dB | 256QAM | 9039563986 | 154825 | 42074 |
| Downstream 3 | 12 | 645.00 MHz | -3.80 dBmV | 37.64 dB | 256QAM | 9375426056 | 1866 | 8873 |
| Downstream 4 | 13 | 651.00 MHz | -4.50 dBmV | 38.61 dB | 256QAM | 11157426657 | 1398 | 4776 |
| Downstream 5 | 19 | 687.00 MHz | -5.40 dBmV | 38.61 dB | 256QAM | 10840985587 | 980 | 4759 |
| Downstream 6 | 20 | 693.00 MHz | -4.60 dBmV | 38.98 dB | 256QAM | 9573565219 | 682 | 1233 |
| Downstream 7 | 21 | 699.00 MHz | -6.80 dBmV | 37.36 dB | 256QAM | 7647358217 | 984 | 3294 |
| Downstream 8 | 22 | 705.00 MHz | -8.60 dBmV | 37.64 dB | 256QAM | 8252472098 | 1447 | 4147 |
| Downstream 9 | 23 | 711.00 MHz | -6.50 dBmV | 37.36 dB | 256QAM | 8110417512 | 2335 | 9375 |
| Downstream 10 | 25 | 723.00 MHz | -5.20 dBmV | 38.98 dB | 256QAM | 9382500454 | 1014 | 1140 |
| Downstream 11 | 26 | 729.00 MHz | -5.10 dBmV | 38.61 dB | 256QAM | 11345091793 | 1878 | 8097 |
| Downstream 12 | 27 | 735.00 MHz | -5.80 dBmV | 37.36 dB | 256QAM | 7391882817 | 1113 | 3751 |
| Downstream 13 | 28 | 741.00 MHz | -6.00 dBmV | 35.78 dB | 256QAM | 8140687219 | 15613 | 1333 |
| Downstream 14 | 29 | 747.00 MHz | -6.70 dBmV | 31.69 dB | 256QAM | 10875684659 | 16565521 | 1821278 |
| Downstream 15 | 30 | 753.00 MHz | -8.40 dBmV | 30.05 dB | 256QAM | 5827894160 | 19105862 | 2282938 |
| Downstream 16 | 32 | 765.00 MHz | -8.30 dBmV | 37.64 dB | 256QAM | 8834712848 | 895 | 1338 |
| Reset FEC Counters |
Upstream
| UCID | Freq | Power | Channel Type | Symbol Rate | Modulation | |
| Upstream 1 | 42 | 24.20 MHz | 43.50 dBmV | DOCSIS2.0 (ATDMA) | 5120 kSym/s | 64QAM |
| Upstream 2 | 44 | 37.00 MHz | 46.00 dBmV | DOCSIS2.0 (ATDMA) | 2560 kSym/s | 64QAM |
| Upstream 3 | 43 | 30.60 MHz | 44.25 dBmV | DOCSIS2.0 (ATDMA) | 5120 kSym/s | 64QAM |
| Upstream 4 | 41 | 19.40 MHz | 42.50 dBmV | DOCSIS1.x (TDMA) | 2560 kSym/s | 16QAM |
| Status |
| System Uptime: | 4 d: 0 h: 56 m |
| Computers Detected: | staticCPE(1), dynamicCPE(2) |
| CM Status: | OPERATIONAL |
| Time and Date: | Wed 2017-11-01 17:17:08 |
| Interface Parameters |
| Interface Name | Provisioned | State | Speed (Mbps) | MAC address |
| LAN Port 1 | Enabled | Up | 1000(Full) | AC:EC:80:F4:30:F1 |
| LAN Port 2 | Enabled | Down | ----- | AC:EC:80:F4:30:F1 |
| LAN Port 3 | Enabled | Down | ----- | AC:EC:80:F4:30:F1 |
| LAN Port 4 | Enabled | Down | ----- | AC:EC:80:F4:30:F1 |
| CABLE | Enabled | Up | ----- | AC:EC:80:F4:30:F2 |
| MTA | NotInitiated | Down | ----- | AC:EC:80:F4:30:F3 |
| Date Time | Event ID | Event Level | Description |
| 11/1/2017 18:03 | 84020200 | 5 | Lost MDD Timeout;CM-MAC=ac:ec:80:f4:30:f2;CMTS-MAC=00:01:5c:77:6c:57;CM-QOS=1.1;CM-VER=3.0; |
| 11/1/2017 18:03 | 84000700 | 5 | RCS Partial Service;CM-MAC=ac:ec:80:f4:30:f2;CMTS-MAC=00:01:5c:77:6c:57;CM-QOS=1.1;CM-VER=3.0; |
| 11/1/2017 18:04 | 84020200 | 5 | Lost MDD Timeout;CM-MAC=ac:ec:80:f4:30:f2;CMTS-MAC=00:01:5c:77:6c:57;CM-QOS=1.1;CM-VER=3.0; |
| 11/1/2017 18:04 | 84000700 | 5 | RCS Partial Service;CM-MAC=ac:ec:80:f4:30:f2;CMTS-MAC=00:01:5c:77:6c:57;CM-QOS=1.1;CM-VER=3.0; |
| 11/1/2017 18:05 | 84020200 | 5 | Lost MDD Timeout;CM-MAC=ac:ec:80:f4:30:f2;CMTS-MAC=00:01:5c:77:6c:57;CM-QOS=1.1;CM-VER=3.0; |
| 11/1/2017 18:05 | 84000700 | 5 | RCS Partial Service;CM-MAC=ac:ec:80:f4:30:f2;CMTS-MAC=00:01:5c:77:6c:57;CM-QOS=1.1;CM-VER=3.0; |
| 11/1/2017 18:06 | 84020200 | 5 | Lost MDD Timeout;CM-MAC=ac:ec:80:f4:30:f2;CMTS-MAC=00:01:5c:77:6c:57;CM-QOS=1.1;CM-VER=3.0; |
| 11/1/2017 18:06 | 84000700 | 5 | RCS Partial Service;CM-MAC=ac:ec:80:f4:30:f2;CMTS-MAC=00:01:5c:77:6c:57;CM-QOS=1.1;CM-VER=3.0; |
| PacketCable(MTA) Events |
| Date Time | Event ID | Description |
| 10/12/2017 12:24 | 14 | Power Supply Telemetry Log - BATTERY MISSING |
| 10/12/2017 12:24 | 16 | MTA TFTP: Successful |
| 10/12/2017 12:24 | 26 | MTA PROV: Successful! |
| 10/12/2017 12:24 | 3 | Voice Line State Change, Line Number = 1, Prev State = OOS, New State = IS |
| 10/12/2017 12:24 | 3 | Voice Line State Change, Line Number = 2, Prev State = OOS, New State = IS |
| 10/12/2017 12:25 | 3 | Voice Line State Change, Line Number = 1, Prev State = IS, New State = OOS |
| 10/12/2017 12:25 | 3 | Voice Line State Change, Line Number = 2, Prev State = IS, New State = OOS |
| 10/12/2017 12:26 | 16 | MTA TFTP: Successful |
| 10/12/2017 12:26 | 26 | MTA PROV: Successful! |
| 10/12/2017 12:26 | 3 | Voice Line State Change, Line Number = 1, Prev State = OOS, New State = IS |
| 10/12/2017 12:26 | 3 | Voice Line State Change, Line Number = 2, Prev State = OOS, New State = IS |
| 10/12/2017 12:26 | 14 | Power Supply Telemetry Log - BATTERY MISSING |
- DarrenMNov 14, 2017Sr. NETGEAR Moderator
It could be the downstream power levels are to low the lowest they should be is -7 and some are at -8 and a lot of them are close to -7 you may want to have a tech look at the line or if you have a cable splitter connected to the modem try removing it or replacing it.
DarrenM
- vkdeltaNov 14, 2017NETGEAR Employee Retired
you need to call Comcast and fix the line asap. you have too many uncorrectables and "RCS" partial service. Speed is slow due to line quality and not because of DoS attacks.
