mmleach829
May 01, 2017Aspirant
Nighthawk C7000 AC1900 Slow ReadySHARE speeds
I recently tried to start using the ReadySHARE function of the C7000 to archive files on a USB HD attached to the USB port on the C7000. I'm able to connect via the PC but the transfer speeds are VERY slow (< 1 MB/s!). Otherwise the C7000 seems to work fine. I can transfer via FTP to other devices on the network at 15-20 MB/s.
I found similar threads for other devices but no real answers. Here are the suggestions I found (and tried):
- Reboot/Factory Reset. Tried that. Didn't work.
- Update firmware (and then factory reset). According to Google search I have the latest firmware for my ISP (V1.01.23 for Comcast).
- Try connecting via FTP (tried, had similar results)
Is there some setting I can change to fix/improve this issue? 1 MB/s is painfully slow and I'm reluctant to disconnect the drive because I have a really hard time getting the C7000 to recognize the HD in the first place (multiple reboots/factory resets, very tedious...).
What is the Mfr and model # of the USB drive?
USB 2.0 or 3.0?
Does this drive have it's own power adapter as well?
- mmleach829AspirantSeagate Backup Plus Hub 4TB (STEL4000100). USB 3.0. It does have its own power adapter. While that exact model number is not on the supported list, I believe it is a newer version of a supported device and I found a post on this forum specifically identifying this model as working with readyshare
Might try a different USB drive to see if the same thing happens, even a small USB thumb drive and test.
- IrvSpMaster
Question, what OS are you running? Are you wireless or hardwired to the router?
How did you test?
I have a WD 1TB USB 2.0 drive connected to the back USB port on my R7000. Using Windows I connected to Z: the Readyshare drive.
C:\>net view
Server Name Remark
\\IRV8700 Irv's 8700
\\LARAINE-XPS8500
\\READYSHARE readyshare
The command completed successfully.
C:\>z:
Z:\>dir
Volume in drive Z is USB_Storage
Volume Serial Number is 996C-1171
Directory of Z:\
04/22/2017 09:00 PM <DIR> .
01/01/2015 01:00 AM <DIR> ..
05/10/2014 01:54 PM <DIR> $RECYCLE.BIN
05/30/2013 07:15 PM <DIR> AUTORUN
07/23/2009 02:07 PM 28 AUTORUN.INF
11/14/2016 04:00 PM <DIR> netgear_downloader
10/30/2016 12:42 PM <DIR> Pictures
05/30/2013 07:22 PM <DIR> share
11/13/2016 11:24 AM <DIR> System Volume Information
11/03/2016 09:23 AM <DIR> W10_image
04/15/2005 08:48 AM 6,722 WDLOGO.ICO
11/14/2016 02:33 PM <DIR> WS_HOLD
2 File(s) 6,750 bytes
10 Dir(s) 398,320,029,696 bytes free=======================
I then used LAN SPEED TEST to test from my wired PC to the USB drive. The write speed was 244Mbps (30.5MBps), read speed 410Mbps (51.3MBps).
Try using the program and see what results you get. Move the drive to the other port and test again.
I'd suspect the reason the drive isn't on the list is the size, and older drives tested and approved were lower in TB's. It could be the drive size though, so I'd also with another drive, even a flash drive if possible..
OK, so I didn't actually use LAN SPEED TEST but I did test with a 1 TB drive. With that drive I'm getting transfer speeds between 4-7 MB/s which is better but still not what I'd expect. I tried both wireless and ethernet and both were about the same (actually, ethernet seemed to be slightly slower if anything). I also tried both Windows Explorer Readyshare and FTP, and both of those had similar results. So, here are my questions:
- Is the issue really just with the size of the drive? I haven't tried a small USB stick to see if even smaller is even faster (I could but it is so annoying to have to factory reset the router to get the new HD to show up). But really, attaching the 4 TB drive was the whole point, since it is meant to be an archive drive for all of the movies that I've watched.
- If size is a factor, is there a recommended way to reformat/partition the 4 TB drive to get better transfer speeds.
- Overall, it seems like the readyshare functionality has significant issues (difficulty recognizing HDs, poor transfer speeds with large drives). One of the main reasons I bought this router was to get this archive functionality, but it really just doesn't work the way I anticipated. Does anyone have any recommendations for other routers that do this better, or other options? I don't really want to buy a new router but this is a bummer
- mmleach829AspirantI will try to do that. First a few quick thoughts:
1. There is only one port on my router and I believe it is USB 2.0. I think there is another similar model that has a USB 2.0 port on the back and a USB 3.0 port on the front.
2. I agree that most of the drives in the compability list are smaller but the reason I chose this one is that there is a 4 TB drive in the list and that drive is the predecessor of the drive I have. So I assumed the size wouldn't cause an issue.
3. Running Windows 10 and wireless connection. I can try wired connection but I doubt that is the issue because, as I mentioned previously, I'm getting 15-20 MB/s wirelessly via ftp to another device on the network.
4. I have tried connecting two ways, both with similar results: (1) Run -> \\readyshare and then dragging and dropping via Windows Explorer, (2) ftp using the address in the genie - mmleach829AspirantNo particular reason for not doing LAN SPEED TEST other than that I thought it would take more time. I figured it would make more sense to try different HDs first.
I have not tried another cable but when I connect the HD to the computer (via USB 2.0) I get 25-30 MB/s transfer rate.
As I mentioned previously, I realize that using a small solid state drive might be faster (and I still might try it to see how much better it works than the 1 TB drive) but the whole point for me is to have a LARGE archive drive, so it doesn't really matter to me if it's faster with a small drive.- IrvSpMaster
No, it wouldn't take more time other than to d/l it and install it... minutes. However we'd have common ground and test method with same 'files'.
Changing cables on the router connection will rule out a bad cable. If you used the same cable on the PC then that is OK and a valid test.
Using a flash drive is another way to help rule out the router as the problem. If its speed is the same then it isn't the drive.
We're trying to determine if the problem is the drive or router.
Connecting to a PC and using a drive is completely different that on the router in terms of how it is accessed. Direct connect on a PC is always faster. Much more overhead to go out to the LAN to the router and to the disk. However as I've posted I get resonable speeds (I'm on an R7000 though).
In reading back in this thread I noticed this:
Yes, that is the correct version (see http://netgear-us.custhelp.com/app/answers/detail/a_id/25477/~/current-firmware-version-for-netgear-cable-modem-routers) but where did you get that version from? I ask as the Support page (https://www.netgear.com/support/product/C7000.aspx#download) doesn't show any upgrades available?
Quite possible the F/W is the problem. Might have to check with the ISP as they might be responsible for that version?
