Dexter11
Apr 19, 2017Tutor
Nighthawk C7000 AC1900 Slow speeds
I have Comcast Blast internet and was getting a little over 100mbps with the xfinity router but I decided I was tired of renting so I bought a surfboar modem that also got roughly 100mbps. The surfbo...
- Apr 24, 2017
Hello Dexter11
It does sound like that may be the issue since your old modem is active. Your line can do any speed its just the coding assigned to the modem that limits what speed you get. From what you say it sounds like your old modem is assigned the higher speed and the new modem is assigned a lower speed so it may be even charging you for 2 connections on your bill.
DarrenM
Dexter11
Apr 23, 2017Tutor
hey Darren, Thanks for the response. I have not done that yet but it sounds like a great idea. It just seems odd to me because when I switch back to my rented modem (I didnt return it yet) I get fast speeds. I just swaped it and my speed test came back at 242mbps. Then I switch it back to the Netgear and it goes straight back to 30mbps. I also reactivated the modem about 4 different times thinking maybe there was a mistake there. I'm going to have to call comcast monday. I know my line in is definitely providing the service since my old router has the speeds. I guess if this doesn't work I'll have to take the netgear back for a new one. If comcast didn't do like you said and assign it a slow speed the modem must be defective. Thanks again, I didn't think of that...
DarrenM
Apr 24, 2017Sr. NETGEAR Moderator
Hello Dexter11
DarrenM
- Dexter11Apr 25, 2017Tutor
Yup thats exactly what happened. I spoke with comcast yesterday and they discovered that they sent the wrong boot file to my modem when I activated it so it was limited to the 30mbps. She sent the correct boot file over and I'm getting my 200mbps now. Thanks for you help!
