desdawg's avatar
desdawg
Nighthawk C7000 slow speed requiring reboot every day
Router works great after a power cycle.  Download speeds are about 50 Mbps in farthest room from router and over 100 Mbps in same room as router.  However, when I wake up in the morning, the speeds are about 4 Mbps in farthest room and 20-30 in same room.  If I power cycle the router (disconnect power cord) and let the router reboot, the speeds recover.  Is there a cache or something that gets cleared when I do a power cycle?  How can I avoid having to reboot each morning to recover my download speeds?
    • desdawg's avatar
      desdawg
      Actually, we use both.  I used the Netgear Analysis app and it said the channel I was using was the best one to use.
      • vkdelta's avatar
        vkdelta
        NETGEAR Employee Retired
        what client do you have on your laptop?
