heylookitsemus
Feb 12, 2018Aspirant
Nighthawk C7000 Spectrum Cable, wired connection drops randomly however wireless stays perfect.
Pretty much title. I have a c7000 using spectrum cable. However I had this model in arizona with a different isp and had the same issue. Only the wired connection is dropping, however the wir...
antinode
Feb 12, 2018Guru
> [...] I had this model in arizona with a different isp [...]
Same unit? Different unit? Firmware version?
> Only the wired connection is dropping, [...]
"the wired connection" to what? Multiple devices? Known-good
cables?
- vkdeltaFeb 13, 2018NETGEAR Employee Retired
pls post power table and event log.
- heylookitsemusFeb 15, 2018Aspirant
Sorry didn't specify. What I meant by "wired connection" is the connection to my computer via ethernet cable. Brand new cable. The connection will be working just fine and then will drop for a couple or few minutes then get back on. However, the connection on other devices via wifi don't drop when the wired ethernet connection drops.
- vkdeltaFeb 15, 2018NETGEAR Employee Retired
your logs/screenshots were not attached in your message. Please attach them again here.
