pdxbears
Feb 22, 2018Aspirant
Nighthawk c7000 Voice Cuts Out
Hi! I have a c7000 that has never worked as advertised. It can't handle even a couple of WiFi connections without VOIP cutting out so I've been forced to use my old R7000 for WiFi since I bought the ...
DarrenM
Feb 23, 2018Sr. NETGEAR Moderator
Are you able to provide the logs and power levels of the modem?
DarrenM
- pdxbearsFeb 24, 2018Aspirant
I'm happy to, but not sure how. This chat interface won't allow me to attach text files. I can paste the logs in this window or make an image of them I guess. Which logs would you like? Looks like there are Logs, Event Log, EMTA Event Log, and various information screens.
Thanks!
Stephen
- DarrenMFeb 27, 2018Sr. NETGEAR Moderator
Event logs and a screenshot is fine.
DarrenM
- pdxbearsMar 03, 2018Aspirant
It won't let me attached anything but PDFs, so I'll just paste into this window below. Are these the logs in question? Thanks!
<tabindex=-1>Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 1 513000000 Hz -1.7 dBmV 37.1 dB 0 0 2 Locked QAM256 2 519000000 Hz -1.8 dBmV 37.1 dB 0 0 3 Locked QAM256 3 525000000 Hz -1.8 dBmV 37.1 dB 0 0 4 Locked QAM256 4 531000000 Hz -1.5 dBmV 37.1 dB 0 0 5 Locked QAM256 5 537000000 Hz -1.7 dBmV 37.1 dB 0 0 6 Locked QAM256 6 543000000 Hz -1.7 dBmV 37.0 dB 0 0 7 Locked QAM256 7 549000000 Hz -1.7 dBmV 37.0 dB 0 0 8 Locked QAM256 8 555000000 Hz -1.7 dBmV 36.9 dB 1 0 9 Locked QAM256 9 561000000 Hz -1.7 dBmV 36.5 dB 2 0 10 Locked QAM256 10 567000000 Hz -2.0 dBmV 36.9 dB 1 0 11 Locked QAM256 11 573000000 Hz -2.1 dBmV 36.8 dB 3 0 12 Locked QAM256 12 579000000 Hz -2.0 dBmV 36.8 dB 4 0 13 Locked QAM256 13 585000000 Hz -2.2 dBmV 36.7 dB 4 0 14 Locked QAM256 14 591000000 Hz -2.5 dBmV 36.6 dB 9 0 15 Locked QAM256 15 597000000 Hz -2.6 dBmV 36.5 dB 11 0 16 Locked QAM256 16 603000000 Hz -2.7 dBmV 36.4 dB 8 0 17 Locked QAM256 17 609000000 Hz -3.0 dBmV 36.3 dB 0 0 18 Locked QAM256 18 615000000 Hz -3.3 dBmV 36.2 dB 0 0 19 Locked QAM256 19 621000000 Hz -3.5 dBmV 36.0 dB 0 0 20 Locked QAM256 20 627000000 Hz -3.7 dBmV 35.8 dB 0 0 21 Locked QAM256 21 633000000 Hz -4.1 dBmV 35.6 dB 0 0 22 Locked QAM256 22 639000000 Hz -4.4 dBmV 35.3 dB 0 0 23 Locked QAM256 23 645000000 Hz -4.7 dBmV 35.1 dB 0 0 24 Locked QAM256 24 651000000 Hz -4.6 dBmV 35.2 dB 0 0 Description Count Last Occurrence Target Source
[SUCCESS: User interface login ] 1 Sat Mar 03 11:23:35 2018 192.168.100.2:80 192.168.100.3:51435
[TCP- or UDP-based Port Scan ] 3 Sat Mar 03 02:33:15 2018 73.164.***.***:59788 75.75.75.75:53
[UPnP set event: ] 1 Fri Mar 02 19:06:54 2018 0.0.0.0:0 192.168.100.6:0
[TCP- or UDP-based Port Scan ] 3 Fri Mar 02 19:05:19 2018 73.164.***.***:52499 75.75.75.75:53
[LAN access from remote ] 2 Thu Mar 01 19:04:42 2018 192.168.100.3:3074 65.55.42.179:13428
[TCP- or UDP-based Port Scan ] 1 Thu Mar 01 18:30:45 2018 73.164.***.***:38617 75.75.75.75:53
[LAN access from remote ] 2 Thu Mar 01 17:42:37 2018 192.168.100.3:3074 65.55.42.179:13464
[TCP- or UDP-based Port Scan ] 22 Wed Feb 28 17:11:44 2018 73.164.***.***:54089 216.58.216.142:443
[Firewall Up ] 1 Sat Feb 24 20:45:58 2018 ---.---.---.---:--- ---.---.---.---:---
[Internet connected ] 1 Sat Feb 24 20:46:00 2018 73.164.***.***:0 0.0.0.0:0
[Public Network Interface up ] 1 Sat Feb 24 20:45:58 2018 ---.---.---.---:--- ---.---.---.---:---
[Time Of Day established ] 1 Sat Feb 24 20:45:42 2018 ---.---.---.---:--- ---.---.---.---:---
[Internet disconnected ] 1 Sat Feb 24 20:44:02 2018 ---.---.---.---:--- ---.---.---.---:---
[SUCCESS: User interface login ] 2 Sat Feb 24 20:43:47 2018 192.168.100.2:80 192.168.100.3:61688
[TCP- or UDP-based Port Scan ] 4 Sat Feb 24 13:12:19 2018 73.164.***.***:56220 74.125.199.189:443
[SUCCESS: User interface login ] 1 Sat Feb 24 11:48:25 2018 192.168.100.2:80 192.168.100.3:51677
[TCP- or UDP-based Port Scan ] 22 Sat Feb 24 11:23:56 2018 73.164.***.***:58164 75.75.75.75:53
[SUCCESS: User interface login ] 1 Mon Feb 19 21:03:06 2018 192.168.100.2:80 192.168.100.3:53028
[TCP- or UDP-based Port Scan ] 7 Mon Feb 19 20:02:44 2018 73.164.***.***:62554 216.58.193.78:443
[UPnP set event: ] 1 Sun Feb 18 19:10:36 2018 0.0.0.0:0 192.168.100.6:0
[Time Of Day established ] 1 Sun Feb 18 12:35:52 2018 ---.---.---.---:--- ---.---.---.---:---
[TCP- or UDP-based Port Scan ] 12 Sun Feb 18 09:36:04 2018 73.164.***.***:59968 75.75.75.75:53
[UPnP set event: ] 2 Fri Feb 16 19:46:43 2018 0.0.0.0:0 192.168.100.6:0
[TCP- or UDP-based Port Scan ] 2 Thu Feb 15 07:44:13 2018 73.164.***.***:53565 75.75.75.75:53
[UPnP set event: ] 1 Wed Feb 14 19:03:39 2018 0.0.0.0:0 192.168.100.6:0
[TCP- or UDP-based Port Scan ] 16 Wed Feb 14 06:45:19 2018 73.164.***.***:49424 216.58.216.132:443
[UPnP set event: ] 1 Sun Feb 11 20:02:15 2018 0.0.0.0:0 192.168.100.6:0
[TCP- or UDP-based Port Scan ] 1 Sun Feb 11 18:20:42 2018 73.164.***.***:58357 75.75.75.75:53
[Time Of Day established ] 1 Sun Feb 11 12:35:51 2018 ---.---.---.---:--- ---.---.---.---:---
[TCP- or UDP-based Port Scan ] 4 Sun Feb 11 11:44:25 2018 73.164.***.***:39392 75.75.75.75:53
