wally9156
May 17, 2020Follower
Nighthawk C7000v2 connectivity issues
Good day.
Just purchased a new Nighthawk cable modem/router combo. works great when connected, but am having a sporadic issue where it will drop the internet connection. tested with the ISP provided, and it is definitely the Nighthawk. For the most part, when I reset the router, everything is fine.
The second part of the issue is that I am unable to log in to routerlogin.net or com, or even the modem's web address. it asks for the username and password, and then the internet browser will just cycle after I enter those. I am able to access the Genie app, however.
Any help is appreciated.
1 Reply
I would start with a factory reset and reinstall.
I'd also try a different browser or even pc when access it to see if that helps.
when you're able to log in through the browser, get a screen snip of the modem cable connection page and the logs.
If you have any splitters, attenuators, or amplifiers in line, I'd remove them.
