jdicicco7
May 16, 2023Tutor
Nighthawk C7000v2 losing connection frequently
Have a Nighthawk router that is about 3 years old. It keeps dropping connection, when I unplug the router and plug it back in it will allow access for maybe a hour at a time. Sometimes it brings...
- Jul 04, 2023In a delayed follow-up on my issue, a couple weeks ago, my internet just randomly started working normally without any drops. Then, Xfinity followed up thru the Twitter DMs I had initiated with them. It appears there was an issue in my area. They didn't go into specifics, but a tech looked into supposedly and the issue is fixed. Internet is running smoothly and perfectly. Thank goodness I didn't spend $$ on a new device or start (gulp!) renting from them.
May 16, 2023Guru - Experienced User
You have lots of Criticals in the logs. The ISP needs to look and review Criticals, Errors and Warnings seen in the logs. This indicates a signal problem from the ISP.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
jdicicco7
May 17, 2023Tutor
Thank you! I have an tech coming tomorrow, I will show him your notes while he is here.
- FURRYe38May 17, 2023Guru - Experienced User
- stonecoldjediMay 18, 2023Tutor
Out of curiosity, is your ISP Xfinity?
I have a C7000v2 experiencing what appears to be the same thing as you. Would love to know if and when you get this sorted out, and how you got resolved.
I have my own thread open with my issues: https://community.netgear.com/t5/Cable-Modems-Gateways/C7000v2-Wifi-connected-without-internet-then-goes-back-to-normal/m-p/2313249
- jdicicco7May 18, 2023Tutor
Yes, we use xfinity.
I looked at your post, they too have mentioned that our modem may not be compatible after their upgrades.
A lot of other residents in NH have been complaining about the same on reddit.
I have a tech coming today, I have mentioned the results from this thread. When they arrive, I am sure they will find nothing to be their fault and say that we need to buy a new modem.
Of course they will. Plus, now that they are DRM-ing OTA local NBC affiliate broadcasts to force people to get cable, because the cable boxes are devices to decrypt the signal. Xfinity is ridiculous.
I do hope they don't tell me it's an incompatible device, because I will throw their own information back into their face.
I honestly would have no problem upgrading my own equipment. I did get a great Amazon Renewed deal on this C7000v2 for 40+% off the brand new price. And it worked like new rom the start. I'd only get a new device now if I can get a similar great deal I did then.
Any info you get and can pass along would be most appreciated.
We don't use cable TV, just internet. We don't have a cable TV box either.
So far he said that at some point in this house there were so many connections they had splitters on the outside to run more connections. The more you split the less signal you get, so he thought that was the issue and it was fixed.
Now they are trying to connect inside it still won't. He said it looked like router was doing a firmware update but now it should be able to connect.
- FURRYe38May 18, 2023Guru - Experienced User
Be sure to have the tech power OFF the modem for 1 full minute then back ON.
Just wondering, is Xfinity charging you for the tech to come out?
That is TBD.
The chat agent said that if they come to the house and determine the issue was because of xfinity, they will not charge me. But if they come to the conclusion that this is some how my fault they will.
I'm no spring chicken here, and I've dealt with this crap from xfinity and Verizon in the past, so I am anticipating a bill that I will end up arguing.
Fingers crossed you don't. I'll be with you raising a stink, too. 😉
- stonecoldjediMay 26, 2023Tutor
Just checking in to see what your outcome was.
- stonecoldjediJul 04, 2023TutorIn a delayed follow-up on my issue, a couple weeks ago, my internet just randomly started working normally without any drops. Then, Xfinity followed up thru the Twitter DMs I had initiated with them. It appears there was an issue in my area. They didn't go into specifics, but a tech looked into supposedly and the issue is fixed. Internet is running smoothly and perfectly. Thank goodness I didn't spend $$ on a new device or start (gulp!) renting from them.
