ShelboTron's avatar
ShelboTron
Nighthawk C7000v2 needing frequent rebooting
I just got this router/modem from Best Buy roughly 3 months ago. Everything seems to work great for a couple of weeks at a time. I have a 600mbps plan, so I definitely notice when the internet gets slowed down. It's happened since I purchased this model. My wifi gets really weak, and my speeds on ethernet are slow. Pictures load slow, sites load slow, etc. When it starts to do this, I do a speed test, and sure enough, it shows I'm only getting about 10-12mbps on my download speed. When I should be getting 600. So I reboot the Nighthawk, and bam right back up to 600+ speeds. I have to do this about every 2 weeks since I've gotten it. Is there a fix for this? Any suggestions? Firmware shows 1.03.08. Thanks for any help.
  • FURRYe38's avatar
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Is Smart Connect enabled or disabled on the modem?
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    • ShelboTron's avatar
      ShelboTron
      Okay so I did have the channels on auto...so I changed them to what you suggested. However it's not just my wifi that drops. It's my ethernet/direct connection to my PC that also shows the slow down. I have always had to reboot it to get it to fix again.
      Here's the event log page.
      2024-5-15, 14:12:39Notice (6)WiFi Interface [wl1] set to Channel 48 (Side-Band Channel:N/A) - Reason:INTERFERENCE
      2024-5-15, 14:12:10Notice (6)WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:N/A) - Reason:INTERFERENCE
      2024-5-15, 14:12:06Notice (6)WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:2) - Reason:GUI
      2024-5-14, 02:04:58Notice (6)Honoring MDD; IP provisioning mode = IPv6
      2024-5-14, 02:04:42Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:04:33Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:04:32Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:04:30Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:04:29Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:04:27Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:04:26Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:04:15Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:04:14Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:40Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:39Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:36Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:35Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:34Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:32Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:29Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:28Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:25Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:24Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:23Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:21Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:18Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:17Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:12Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:11Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:10Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:08Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:07Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:05Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:04Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:03:03Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:02:53Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:02:52Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:02:44Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:02:44Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      2024-5-14, 02:02:40Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
      • FURRYe38's avatar
        Lets see the cable connections log data please.
        Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
