Ctrygrl's avatar
Ctrygrl
Follower
May 16, 2021
Nighthawk C7000v2
I want to set up a router VPN but don't know if my Nighthawk C7000v2 is compatable with a VPN or does the fact that it is a modem/router make it incomapatable with VPNs? I know IPVanish says in their "connect your existing router" section that if you download the wrong firmware it can destroy your router.
So far none of the VPN services that I have checked list my router.
  • > I want to set up a router VPN but don't know if my Nighthawk C7000v2
    > it incomapatable with VPNs? [...]
       Pretty much, yes.  The firmware in a typical DOCSIS-compatible
    modem+router is off-limits to the user.
          https://kb.netgear.com/000036375
       I'd expect that trend to continue.
       One possibility would be to configure your C7000v2 as a modem only
    ("bridge mode"), and get some VPN-compatible (separate) router to use
    with it.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for
    "Connect Your Modem Router to a Router After Installation and
    Activation".
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    Cable Modems & Routers
