shawnpwilson
May 31, 2018Aspirant
Nighthawk C7100V Comcast Extreme Pro 400Mbps - not getting the speed hard wired
I just upgraded to comcast extreme pro 400Mbps and am not getting the full speed thru the modem with a direct hard wired connection.
It peeks anywhere from 250-275.via speedtest.net. comcast tech visited my home with their modem and the speed is there thru their modem... I saw it peek to 500Mbps... so they are definitely pumping out the bandwidth. The c7100v modem is correctly registered with comcast with correct provisioning according to them. They suggested calling netgear for support to see why the c7100v only gets up to 275. Any one else have similar issue with their c7100v with comcast and their extreme pro 400Mbps package? Any help is much appreciated. I am on firmware v2.01.33
- vkdeltaNETGEAR Employee Retired
What tool are you using to test?
Is comcast sure it is provisioned on 400 Mbps config file?
Please post your event log and connection table. If you have lot of uncorrectables, then that may explain the problem.
- shawnpwilsonAspirant
I think I posted a false alarm... when I was testing I was hitting speedtest.xfinity.com using IE and MS Edge browsers (with norton security plugins). When I changed to using Google Chrome browser with no plugins I saw it peaked over 400 averaging about 350)... I'm sure there are probably other small factors (ie time of day, pc, etc) that may not let me see the full 400 consistently all the time.
thanks for update. glad you can see higher speeds.
