sfdurango
Jan 29, 2018Guide
NightHawk C7800 DoS Attacks
Having frequent DoS Attacks last couple months: SYNC FLOOD or UDP SCAN or ECHO CHAR GEN Netgear's brochure for this NightHawk C7800 says: SECURITY Denial-of-service (DoS) attack prevention...
sfdurango
May 24, 2018Guide
I do have (1) Wireless Porch camera. This is one of the locations on my LAN that has dropped off assuming as a result of a DOS attack. Most times now, my Amazon Alexa device states: "I am having problems connecting to the internet." When I check, I find that my main Wifi name (SSID) is missing (primary Wifi not discoverable on Wifi search) [I have 4 Wifi names: (1) for 2.4 (1) for 5.0 (1) for 2.4 extender and (1) for 5.0 extender). My recourse always is: reboot the router! I am still getting DOS Attacks (daily) but , so far, the noticeable disruption occurs only about once every few weeks! One noticable IP address that continually (Dos) attacks me is: Hurricane Electric LLC 184.105.139.105 Fremont, CA. So far, I'm just living with the occassionaly disruption!
BlockIt311
May 25, 2018Aspirant
Enable ddos protection if it has it. If not you can always block the ip. Also try unplugging the repeater jus t Incase it’s contributing to the issue. Next time it happens do a packet capture with wire shark and email it to your isp. They may put it on their blacklist for you. Let me know what you find out and good luck.
- sfdurangoMay 25, 2018Guide
I did discover that "Disable Port Scan and DoS Protection" was disabled on my modem. (How, I haven't a clue). So I unchecked that box. Still having DoS Attacks, though. As far as blocking IP addresses, I wish Netgear provided a "Blacklist" feature, or other means to do it. So far, I haven't discovered a means via my Netgear C7800. I have checked on that "wire shark" for a packet capture and will keep that in mind for the future. Thanks!
