akeele
Oct 26, 2021Star
NightHawk CAX 30 slows until Factory Reset or config restore
I have experienced this issue with this router since buying it at Costco in July 2021. My firmware is up-to-date with version 1.4.10.8. I do not have any special port forwarding or access control con...
Oct 26, 2021Guru - Experienced User
How are you testing speeds?
Wired?
Wireless?
Are you testing over the 2.4ghz or the 5ghz?
What device are you testing on?
- akeeleOct 26, 2021Star
Per my original post, "After initial setup, I get 350 - 500Mbps directly from the router over Xfinity that is provisioned for 400 Mbps. Within hours, the rate drops to 120 - 150 Mbps."
I want to test the router's ability to handle what is provisioned. This means I logged into the router's Netgear administrative console to test internally from the router itself to avoid any potential network or wireless issues in getting to the router. I used the speed test tool on the router itself. As such, this test is neither wired nor wireless, and wireless frequency is not relevent.
The device I'm testing on: directly from the router
Here is a link on how to check the speed between your ISP and your router: https://kb.netgear.com/000038894/How-do-I-check-my-Internet-speed. This speed test should be fairly constant, and should not be influenced by resetting the router to factory defaults, or simply reloading the current config.
- plemansOct 26, 2021Guru - Experienced User
"directly from the router" isn't always the best choice as it doesn't let you choose which server it tests off.
And if it chooses a slower server, you get slower speeds showing even if they aren't accurate.
its why if you look on here, you see us recommending people wire a pc/laptop into their router and test that route.Because then you can try different speedtest sites and even servers on those sites.
Thanks for the advice.
Unfortunately, I do not have an Ethernet adpater for my laptops. However, I can say that testing from 2 Dell laptops (1 is band newand a Galazy 21 phone (Wifi 6 conection) through the CAX30 using Speedtest consistently mirrors what I get on the router's console within +/- 20 - 30 Mbps from multiple testing and multple target servers. My laptop and phone are connecting through 5G from a distance of about 8 - 10 feet.
Again, I am able to reliably fix the slow speed within about 3 - 4 minutes by simply re-loading the saved config file and rebooting. We're talking about improving from 120Mbps pre-fix to a post-fix 400 - 500 Mbps speed in only about 4 minutes' time. The reliability of the fix proves out over across the 4 testing devices (including the router console).
I am not the only person to report this issue and the same fix. https://community.netgear.com/t5/Nighthawk-WiFi-Routers/CAX30-Slow-Internet-Speeds/td-p/2132543.
Anthing you can recommend?
