ThatDudeIan
Jul 25, 2023Initiate
Nighthawk CAX30 only "1 2 3 4" lights on
Just got a brand new Nighthawk CAX30. Plugged it with power cord and coax cable, lights flashed and blinked at first but now only solid " 1 2 3 4" lights are on, not even the power light comes on. Unp...
Jul 25, 2023Guru - Experienced User
Disconnect the ISP coax line from the modem. Perform a 30-30-30 reset. Does this clear the LED condition at all?
If it seems to clear the LED condition, re-connect the ISP coax line to the modem and see if you can walk thru the setup wizard with a wired PC and web browser at 192.168.1.1.
If not, please reach out to DarrenM
