ThatDudeIan
Jul 25, 2023Initiate
Nighthawk CAX30 only "1 2 3 4" lights on
Just got a brand new Nighthawk CAX30. Plugged it with power cord and coax cable, lights flashed and blinked at first but now only solid " 1 2 3 4" lights are on, not even the power light comes on. Unp...
DarrenM
Jul 25, 2023Sr. NETGEAR Moderator
If the unit still does not respond after a full reset then I suggest returning the unit for a new one or you can contact our support for an RMA of the unit. https://my.netgear.com/support/contact.aspx
Thanks
DarrenM
ThatDudeIan
Thanks, unfortunately it didn't. The "1 2 3 4" lights stayed on solidly through holding the reset button for 30 seconds.. and again for 40 seconds (my ocd made me think I counted 30 seconds too quickly). It's DOA.
