fhdeybcfg
Apr 24, 2023Aspirant
Nighthawk cax30s Wifi issue
Hello, When my phone connect to the wifi some of the apps are not opening or loading. For example the xfinity app and nighthawk app are not opening or connecting. Also Twitter app not loading images and videos. This only happens to my s22u phone and samsung tablet. For ipad and laptop works fine. When my s22u phone switch to the mobile data all the apps will work. So far I tried downgrade firmware(the firmware im using is 1.4.11.2), factory reset and it fix the issue. But after 1 day or half hour this issue will come back agagin. This issue has been bugging me for 3 weeks.
Thank you
Be sure any MAC ADDRESS randomizers are disabled on phones while your at home:
What channels are you using? Try 1 and 40.
Try disabling AX mode.
- fhdeybcfgAspirant
Hello, I did disabled random mac address on my phone. And I also changed wifi channel to 1 and 40. AX feature disabled but still not working.
Thank you
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-routerPlease post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
