JEdgeston
Sep 29, 2022Aspirant
Nighthawk CAX80 not connecting to the internet (Mediacom)
I moved to Pontiac, Il in June 2021. Once I was moved to Pontiac, I had to use the local ISP call Mediacom. Did research to find out that my Nighthawk CAX80 modem\router was approved to be setup on Mediacom's network. Everything was connecting find until Dec. 21. In Dec. 21 my Nighthawk CAX80 modem\router started loosing the internet connect. I was able to resolve the issue with a simple restart, until Sept. 22. In Sept 2022, I've lost my connection to the internet and was not able to reestablish a connection. I did my normal troubleshooting with Netgear and with Mediacom, but I still could not connect to the internet using my Nighthawk CAX80. I'm on the current Firmware version and checked for Firmware updates, but there are not new updates. I got so frustrated that I got a modem\router directly from Mediacom. I've been on my Mediacom modem\router for the past couple of days and there are no internet issues. The bad thing is I have a Nighthawk CAX80 modem\routher that I spent over $400 dollars for that I cannot use due to I cannot get to the internet. I would like to use my Nighthawk CAX80 router, instead of paying an additional cost for a modem for Mediacom.
Make and Model
Nighhawk CAX80
Firmware:
Firmware Version V2.1.4.2
What are the front LEDs showing?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerHave the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html- JEdgestonAspirantI discussed this issue with Netgear. I was informed that the agent has a fix for this issue, but would not tell me if this was a setting needed to be configured or provide a patch to correct this issue unless I paid a year support subscription. Is there another business in his world that has a bug in a product they produced, but holds their user hostage so that they can milk more money from their customers.All of the things that was discussed in the response here was already done...
Well if your in contact with NG support then you'll need to follow up with them then.
Good luck.
