TechMiner's avatar
TechMiner
Nighthawk CAX80 VLAN Compatability
Hello all!
Thank you first of all for any help offered.
I want to connect the CAX80 WAN port directly to a VLAN port on a Cisco switch.
What I'm trying to do is connect a WAN port from a Modem to the CAX80 that is on a different floor through the switch.
Modem_WAN ==> Cisco Switch_VLAN_Port1 ==> CAX80_WAN
Thanks again!
TechMiner
  • FURRYe38's avatar
    The CAX80 doesn't have a ethernet WAN port. The CAX80 requires the use of the RG6 cable coax signal connection for it to work.
    • TechMiner's avatar
      TechMiner
      Wow,
      Thank you for this amazingly quick reply FURRYe38!
      So the LAN (Multi-Gig 2.5/1G) is used for what sir?
      TechMiner.
      • plemans's avatar
        Just for that,  a LAN port.
        The CAX80 needs a coaxial input or it goes into a boot loop.
        If you already have services coming in, you don't need a modem/router combo device. You just need a router.
