TaiV
May 02, 2022Tutor
Nighthawk CAX80
helo everyone , does anyone know what happened to my nighthawk CAX80? I'm unable to factory reset it ( reset button), the LED just stay on like that( the picture) and disconnected on nighthawk mobile app. No wifi rightnow, tried unplugged re plugged it but doesn't help at all. thank you all
You can try starting an RMA
How do I request a Return Material Authorization (RMA)? | Answer | NETGEAR Support
Can you access it by hardwiring a pc/laptop into it?
Try its default ip address of 192.168.100.1
