ReidHJ
Oct 23, 2022Aspirant
Nighthawk cm1200 and Sony Bravia
Looking for some help- thank you!
When connecting to WiFi:
Connected
Network does not have access to internet: failed
When connecting with an Ethernet cable or hotspot:
Connected
Network has access to internet
All other devices in my home connect to internet via WiFi without a problem.
I have unplugged and plugged in router, modem and tv in all sequences imaginable. I have factory reset tv- several times. Still no internet via WiFi.
I’ve read that there have been issues with Bravia and Netgear- but have not found a solution to fix the problem.
Pulling my hair out. Thanks for any assist.
Reid
Connected
Connected
Reid
The CM1200 is a modem only device.
It has no routing capability.
So you need to go modem----->router---->devices
And the vast majority of ISP's can only connect 1 device to the cm1200 (even though it has more ports).
So if you had more than 1 device connected, power off the modem and router and disconnect everything from both.
wait 2 minutes
Power the modem on with nothing connected.
Wait 2 minutes
connect port 1 on the modem to the router.
power the router on and wait 2 minutes.
go through setup on the router
- ReidHJAspirantThank you! Tried your great suggestions. Unfortunately no luck. I will either upgrade router or depend on Ethernet for this devise.
Appreciate your time and input.
Reid
