pjchristopher's avatar
Aug 23, 2020
NightHawk CM1200 only getting 30 mbps hardwired.
I tested my old Motorola modem and getting 130 mbps but when I register netgear with xfinity I only get 30 mbps. All default configurations. What could be the issue? I am switching To netgear because my plan supports 500 mbps but my old Motorola only supports 130.
  • plemans's avatar
    Do you have more than 1 device connected to the cm1200 or do you have a router using WAN aggregation?
    • pjchristopher's avatar
      pjchristopher
      I have google Nest Mesh setup but I plugged just my laptop direct to modem and only getting 30 mbps. No other devices hooked up. If I swap out with my old one I get the 130 direct from Ethernet port.
        pjchristopher
        Should I have hooked plugged my Ethernet into port 3/4 instead of 1/2 since I only have an ISP or 500 mbps?
