JTorio
Feb 10, 2016Aspirant
Nighthawk R8000 X6 combined with AC1750 model C6300 Cable modem
Hello everyone, Trying to get a little help and some advice on my system. I am currently in the process in upgrading my internet service with COX communications to get the Ultimate Internet Package an...
vkdelta
Feb 11, 2016NETGEAR Employee Retired
Yes, you can use both at the same time. Actually you should have got CM600 modem instead of C6300.
But if you have C6300 already, you can turn it is Bridge mode (turn off Router mode) and connect R8000 behind it.
R8000 is much higher spec'ed product and has more features than C6300 and it makes sense to operate it as a router.
JTorio
Feb 11, 2016Aspirant
vkdelta,
Thanks for the response. After speaking to one of the Techs at COX, they told me that the C6300 would work for my internet package I was getting but I wouldn't be getting the speed that the package was offering because of the 8x4 channeling. I think he was mistaken because the C6300 is a 16x4. After doing a little more research, I am in the process of swapping the C6300 out and getting the C7000. That one is rated at 24x8. I have them coming out on Monday to upgrade my service so I should be ready by then.
Do you guys have any links with pictures or videos to show me how to get the best setup with my equipment? I'm pretty new to the terminology when it comes to networking but I really want to learn the ins and outs to get the best performance out of my home network.
- vkdeltaFeb 12, 2016NETGEAR Employee Retired
Instead of C7000, get a CM600. It is cheaper and fits your needs. If oyu have already got C7000 it is fine.
go to the user manual here and follow section on "Cable Your Modem Router to a Router and Use Bridge Mode" (page11)
http://www.downloads.netgear.com/files/GDC/C7000/C7000_Comcast_UM_27apr15.pdf
sorry, no official videos I am aware of.
Basically you will connect like this:
<ISP COAX CABLE> ---> C7000 ---ethernet port--- R8000 -^-^-^ wireless PCs/laptops
I can help further if needed.
- JTorioFeb 16, 2016Aspirant
Yes, I have already purchased the C7000. I did as it said on page 11 from the manual and was able to bridge it but then I was unable to get access back to the modem. I eventually had to reset the C7000 back to factory in order for me to get it working again. I had issues with it communicating or something with my ISP provider when they went to upgrade my internet. Is there another setting I need to change in order for it to work? I heard that if I keep the router mode on with the C7000 that it my conflict with the R8000. Is that true? I'm just trying to research on what are the best settings to have with my setup. Any and all help is greatly appreciated.
- DarrenMFeb 17, 2016Sr. NETGEAR Moderator
Hello Jtorio
That is correct it would conflict with the R8000 if you leave router mode on the C7000 then you will need to switch the mode on the R8000 to access point.
DarrenM
