JTorio
Feb 10, 2016Aspirant
Nighthawk R8000 X6 combined with AC1750 model C6300 Cable modem
Hello everyone, Trying to get a little help and some advice on my system. I am currently in the process in upgrading my internet service with COX communications to get the Ultimate Internet Package an...
vkdelta
Feb 12, 2016NETGEAR Employee Retired
Instead of C7000, get a CM600. It is cheaper and fits your needs. If oyu have already got C7000 it is fine.
go to the user manual here and follow section on "Cable Your Modem Router to a Router and Use Bridge Mode" (page11)
http://www.downloads.netgear.com/files/GDC/C7000/C7000_Comcast_UM_27apr15.pdf
sorry, no official videos I am aware of.
Basically you will connect like this:
<ISP COAX CABLE> ---> C7000 ---ethernet port--- R8000 -^-^-^ wireless PCs/laptops
I can help further if needed.
JTorio
Feb 16, 2016Aspirant
Yes, I have already purchased the C7000. I did as it said on page 11 from the manual and was able to bridge it but then I was unable to get access back to the modem. I eventually had to reset the C7000 back to factory in order for me to get it working again. I had issues with it communicating or something with my ISP provider when they went to upgrade my internet. Is there another setting I need to change in order for it to work? I heard that if I keep the router mode on with the C7000 that it my conflict with the R8000. Is that true? I'm just trying to research on what are the best settings to have with my setup. Any and all help is greatly appreciated.
- DarrenMFeb 17, 2016Sr. NETGEAR Moderator
Hello Jtorio
That is correct it would conflict with the R8000 if you leave router mode on the C7000 then you will need to switch the mode on the R8000 to access point.
DarrenM
