SWDelmar
Sep 25, 2018Aspirant
Nighthawk Wifi-Router(s) - C7000V & C7100V
Can I initially please ask the differences when comparing Nighthawk Wifi-Routers of - C7000V & C7100V - if clearly possible?
DarrenM
Sep 25, 2018Sr. NETGEAR Moderator
The C7000 is a cable modem/router where the C7100v is a cable modem/router with home phone hookup on it. So if you get your home phone line provided by your cable provider than you would want the C71000v.
DarrenM
SWDelmar
Hello Darren,
Thank you VERY MUCH for presenting that to me.
I recently had saw a higher identical Netgear Wifi/Router while also including the telphone line hookup, but not including this almost identical Product#.
Thank you again,
Shawn Delmar
