Sevvy
Apr 24, 2017Aspirant
Nighthawk X4S AC2600 (D7800) slow wireless speeds
Hi all
- My two year old TalkTalk "Super Router" was giving me a bit of trouble , so i invested over £200 in a Netgear Nighthawk X4S -AC2600 modem router after reading excellent reviews of it in several PC magazines and on various websites.
I always used to get around 30-33 mbps wirelessly with my old fairly basic TalkTalk Huawei HG635 router , but have never achieved more than 25 mbps since replacing it with this supposedly much better Nighthawk D7800
I even had Openreach out who told me to not bother with it and go back to a TalkTalk router ( they sent me a new one ) - surely there must be something i am doing wrong , but the 2.4 and 5ghz channels it uses are , according to the "Netgear wi fi analytics" software im using are already using what it considers to be the best channels.
The router is in exactly the same place as my old one , and even when testing in the very next room , with clear line of sight , the wireless strength drops by around a third .
This happens on my wireless laptop, iphone and android tablet
I have searched everywhere for a UK customer contact phone number , as i am still well withing my 90 days of purchase , but there doesnt seem to be one so that i can speak to someone .
if anyone out there can help , it would be much appreciated
Sevvy
- DarrenMSr. NETGEAR Moderator
Hello Sevvy
Have you tried to change the wireless channels on the router in the wireless settings?
DarrenM
- SevvyAspirantHi Darren - yes I've tried various channels but most make no difference at all , and some make it worse
What speeds do you get while connected via a wired connection?
DarrenM
- SevvyAspirantUnfortunately I don't have anything I can plug into it using Ethernet as my new Lenovo laptop is wireless only -
I also have an iPhone,iPod and Samsung tablet - all wireless -
if I log into the router 192.168.1.1 homepage it shows my incoming broadband speed as 28.8 Mbps , and yet I can only get 15.8 max when using wireless , even right next to the router- DarrenMSr. NETGEAR Moderator
Hello Sevvy
Sometimes a signal device connected to the network could be slowing down the whole wireless network you could test this by removing all devices and adding them 1 by 1 and testing the speed. You will know pretty quick if you start with your laptop only and the speeds are still slow if there is a issue with the wireless on the unit.
DarrenM
- SevvyAspirantThanks Darren - I'll try that tomorrow ( 10.35pm here now)
I'll post my findings on here once I've tried what you've suggested
Sevvy - SevvyAspirantNo difference I'm afraid - Max 16mbs whether one or 5 wireless devices attached
Hello Sevvy
If the modem is under warranty you may want to contact support.
http://www.netgear.com/support/contact.aspx
DarrenM
