ngeorge
Jan 14, 2019Tutor
Nighthawk X4S C7800 randomly dropping WiFi (will not connect)
Hello;
I purchased a Netgear C7800 cable modem/router about 6 months ago -- the two months, it randomly drops either the 2.4 Ghz. or 5 Ghz. wifi channels. This started as an occasional burp, bu...
Scorpi023
Aug 21, 2019Aspirant
I’m having the same problem as well. The first one is, I can’t even connect devices to the WiFi network. I had to try st least 5 times on each one.
None of the devices auto connect. I tried resetting and also changed the WiFi name/password.
I’m 100% confident it’s not my ISP as I’ve never had any issues before I got this device.
I’m definitely returning it as I’ve already wasted a day trying to fix.
And no, I don’t have a lot of interference. I usually select a channel that is free and never had interferences with my old N700.
Aug 22, 2019Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings.
