l3ully
Sep 23, 2016Tutor
Nighthawk X4S D7800
I have an issue with static ip address' on the lan side of router. I have setup address reservations but when I turn on these devices mainly Xbox ones it never gets the IP address set? I have tried rebooting router and devices but that does not fix the problem. I'm on firmware V1.0.1.10
Any help would be appreciated.
Ok I have found the issue, it is the latest firmware V1.0.1.10 that is the problem, rolled back to V1.0.0.48 and is working fine now.
- l3ullyTutor
- l3ullyTutor
I seem to have another issue, occasionally the fibre connection disconnects and does not automatically reconnect, the only way I can get connection back is to reboot router.
