TexARC
Aug 16, 2016Guide
No 5G range with this router?
I replaced the TW cable modem with this Netgear hardware yesterday, configuation was not unusual. I literally have it in a window sill, and am accessing the router wifi from 30 feet away. There is on...
DarrenM
Aug 18, 2016Sr. NETGEAR Moderator
Hello TexARC
You will want to change the wireless channel on your 5ghz network in the wireless settings this will help with signal and range if you find the channel that has the least use in your area.
DarrenM
TexARC
Aug 18, 2016Guide
Thanks for the reply. SHortly after my post, I discovered the nifty WiFi Analytics app, and used it to monitor signal strength as I went through all the channels. since nothing I could do improved the 5G signal reliably, I finally decided to move the cable modem into my living room by linking a few RG-6 drops I put in back when I built the house (6+ miles' of Cat-5, RG-6, and Cat-3 back in 1997, just before wireless became a "thing"). Also used a Cat-5 network drop to connect to my primary switching hub in the home automation closet for the rest of the house. With the cable modem hidden behind a plant only 10 feet away from my easy chair, I get 70% signal strength on 5G and 100% on the 2.4 , regardless of what channel I use. NOT impressed with the hardware but the problem is resolved. Not solved, but resolved. I had hoped it would give me better range outdoors for some PZI wireless cameras I have used in the past with the cable modem provided by TW. THAT's not going to happen unless I drop another run out and add another wifi router, I guess. One step forward, two steps back.
- TexARCAug 18, 2016Guide
from less than 8 feet away:
and
Just for grins, I held my phone 1 foot from the modem router:
. Is this the expected reading on the meter for a channel NO other device/household is on, from one foot away?? Strength 100%, but no where near zero dBm ?
- TheEtherAug 18, 2016Guru
-20 dBm is an excellent signal strength and pretty close to the highest you'll ever see.
