baffalos
Sep 03, 2025Tutor
No Access Control on my CAX80 Gateway
Evidently Netgear has moved access control to the Nighthawk app. I'll be damned if I can find it. Does anybody know if and/or where access control can be maintained in the Nighthawk app. I have se...
Sep 03, 2025Guru - Experienced User
If you had any form of Smart Parental controls enbabled, this moved the WEB UI access controls to the NH app and removes it from the web ui.
If you don't have any need for this feature, would be recommended to do a factory reset on the gateway and setup from scratch using a ethernet connected PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Don't setup using the NH app. After setting up the system, this should move the controls and should now be available to use the web ui Access Controls, if needed at this point.
baffalos
Sep 04, 2025Tutor
I figured that I would need to reset and start over. Thank you for your help.
